Need Help with Where Wires go!
Well lets just say it took too long to get the part. Anyways, I took the bottom of my dishwaher off to get to the part (did not disconnect wires). that I needed to order. Well in the meantime, the wires got pulled off of where they need to be and I have NO idea where they need to go. Was hoping someone could help me before I just try connecting them and hoping for the best.:frowning: :confused: :eek:
There was a schematic drawing in the bottom of my machine that at least tells you which color wire goes to which switch. It also has the terminal numbers if you can see them on the switch. Good luck
