Need help with washer that will not spin
Brand:whirlpool
Model Number:lsq9010pg0
Main Symptom: won’t spin (moves but doesdnt spin fast)
What happens & when: each time used
Parts or tests already tried: dogs, motor connector
Need some help. I was talking to a tech yesterday and performed the tests her suggested.
If it is barely spinning in spin more than likely you have a bad clutch ( Whirlpool 285785 Washer Clutch Assembly | Genuine OEM Part ) on the output shaft of the transmission
Thatt supports my diagnosis. I will order the clutch assembly. Thanks for the help/
Should I replace any other parts while doing this??
Should I order anything else while I am at it??
Check the condition of the motor coupling between the motor and transmission. This is a good time to replace it if it is worn or to upgrade it ( Whirlpool 285753A Washer Motor Coupling | Genuine OEM Part )
also check the condition of the agitator dogs since you’re going to have to remove the agitator anyways you can get just the agitator dogs ) Whirlpool 80040 Washer Agitator Dogs | Genuine OEM Part ) or the whole agitator cam kit ( Whirlpool 285809 Washer Short Cam Agitator Repair Kit | Genuine OEM Part )
