need help with roper washer
had the motor coupling break on mine. while figuring this all out found a second problem. have 2 copper pieces that almost look like nails that hold something together. they fell into the 2 plastic cups that i assume are their to catch them in case they do fall from the spots they originally sit. need help figuring out how exactly they sit in and is their a certain way everything needs to be lined up before i put them back in.
You don’t need these pins. They were there for transportation only.
