Need help with Kitchin Aid Cupling
I cannot find a coupling for this kitchen aid blender
Model ksb5gr4
serial # wr3701500
Its not the screw on type. Please help.
Doug
Hello Dougrok. According to kitchen Aid, AP2930430 is the correct drive coupling and does screw off the unit. Below is a video on how this can be done. Hope this helps.
AP6013694
Dougrok,
Did you get anywhwere with this. I have the same problem, even took the same picture. I ordered the suggested part anyway, but I don’t think it will work.
Let me know if you found a solution.
Well, turns out they are telling you the right part. You won’t get the old one off like they do in the video, though.
You have to get a pair of thin pliers or a thin wrench on the shaft under the old part to stop it from turning. Then use a pliers to loosen that piece left over from the old part. Turn it clockwise to loosen. When it comes off, you will see the shaft is threaded, and the new part spins right on.
It took me 2 weeks to find a wrench thin enough to grab the motor shaft.
Good luck!
[quote=kitrson;653180]I have a kitchenaid glass cooktop and none of the burners seem to work. I have already checked the circuit breaker to make sure that was not the problem.
Relift Xs[/quote]
This is a blender repair thread.
You should repost this and start a new thread.
Good luck!
