Need help with 1990s Kenmore washer stopped draining
I have a 70 series washer that stopped draining. I replaces the pump and the rubber piece that goes between the motor and transmission. And is still does not drain. It fills with water and agitates then I hear the switch go click click then nothing happens. I don’t know what else to check? :confused:
pleas help
Thanks,
Steve
No spin either? Bad lid switch.
Whirlpool 285671 Lid Switch Assembly - AppliancePartsPros.com
Eric
