Need Help Whirlpool Heavy Duty Extra Large Cap. Plus
This Washer Is A Top Loader And While Agitating And Cuming Up On A Rinse Cycle Leaves The Basket Off Center. Causing Water To Pour Out The Back Side Of The Top Of The Basket. Also While During The Spin Cycle Seem’s To Be Unbalanced.EVERY TIME THE WASHER COME TO THE RINSE CYCLE I HAVE TO CATCH IT AND CENTER THE BASKET SO THAT WATER DOES NOT POUR OUT THE BACKSIDE. Need Help Figuring Out What Is Causing The Basket To Stay Off Balance Center Wise During And At The End Of A Cycle. Not Sure If It Might Be A Bearing Or A Warn Out Spring. Any Help Would Be Apprieciated
You might have a loose counterweight spring that attaches to the frame in back. If a rusted frame, you will have to drill another hole in the frame for it.
You can also add another spring to it AP4459650 will help the stabilize the tub.
Awsome Thanx For The Advise And The Part Number I’ll Get On It And See If This Will Help… Again Thank You For Your Time…
Chachi
