When I turn the dail to start , the light does come on but the cycle dosn’t start, although I have let the cycle go to the end, I notice hearing noises that it is trying to run making sounds undernieth where the motor is. It did run once but had a hard time getting started. Smelled electrical burning ordor. Since
then have not been able to get it to run with the water coming in.What should I test for first and next? It is a GE Nautilus. Would getting a repair manual show the propper ohms that I need to know? Normally the water starts making noise when I turn to start.
Thank you
kngpn08
There are two important aspects in creating efficient distance - with control. Controlling the club face is one. The second is proper forearm rotation.In order to maximize every aspect that goes into a golf swing, you must “catch” the ball squarely on the clubface. For most players, getting the clubface squared on the back of the ball is either an accident - or a miracle.Regardless of whether you have a clubhead speed of more than 100 miles per hour, or one that is less than 50 miles per hour, it is paramount that you learn how to control the club face with every club in your bag.Drill: In order to master clubface control, you need to start with the shortest of strokes - the putting stroke - and practice squaring the club face on the ball at impact.Start by drawing a line around the ball, and then on a flat putting green or surface, set the ball down with the line straight up and down and practice “rolling” the ball 8-10 feet so that the line remains constant (straight) throughout its roll.You cannot achieve a straight line with anything less than square contact of the face on the back of the ball. Once you have mastered rolling ball properly from 8-10 feet, increase the distance, then begin to work on squaring the club face with chip shots with a 6- or 7-iron, then pitch shots, then eventually full shots.hot products:TaylorMade Burner IronsCallaway LEGACY DriverPing G15 DriverMIZUNO JPX E600 Irons
