Need help replacing control panel
Hello, I have a Kenmore Elite Dishwasher 630.13959010. Everything mechanically is fine but the problem is that several of the led “lines” on the control panel are not lighting up. I want to replace the control panel so I took the front cover off but I cannot figure out how to remove the control panel from the metal housing. Any help would be greatly appreciated.
Have you removed the two scews on either side of the door latch yet? Not sure how far along in the removal process you are.
