Brand: Speed Queen top load washer purchased in June 2023
Model Number: AWN63RSN116TW01
Main Symptom: After I push start for the washer, lights flash on the control panel and it will not start. To correct this I have to unplug the machine, wait a short period and plug it back in. At that point the washer will start and run appropriately. An appliance mechanic said the washer needs a new control board but did not specify which one. He has not gotten back to me to do the repair. If I can get the correct panel, I can install it. The board in the unit has a sticker on top with the number 205385. On the plastic shield there is an imprinted number 203612. The machine otherwise has worked well to date. Looking at your web site I see two control boards that possibly will solve the problem-OEM20352276 and OEM20992836. The description of what they do is not specific enough for me to know if one of them is the correct one.
Parts or tests already tried: An appliance mechanic said the only issue with the machine is the control board.
