Need Compatible Heating Elements
GE no longer services the heating elements for my 1981 built-in electric range.
I need part numbers for the upper and lower heating elements that are compatible with this model (The top element failed about three years ago and the bottom element failed this year, we cannot afford a replacement range.)
Your model number is missing several digits.
I used JKP97G*06.
Bake element looks like Item 250 in Section 2.
If you click on the picture a new page will open with a better view and a Q&A section. That is where I saw the broil element number.
Best to look at the picture and then see if it physically matches your unit. Each square is 1 inch.
Be sure to check how much the element extends past the back oven wall, too long and it will short out.
Bake Element
AP2031031
Broil Element
AP2031021
Note: I do not work for AppliancePartsPros so it is best to call them.
Thanks denman - You hit a home run for me!
I measured and ordered both parts - WE ARE BAKING AND BROILING AGAIN! Although GE claimed they no longer serviced my model, it appears that both parts came from GE - One of the replacement parts came in a GE box - But GE could not help me!
Thanks again, keep up the good work
You are welcome.
I am glad to hear it worked out for you.
