Name this part! :-)
Brand:
Model Number:110.25852400
Main Symptom: Leaking from the bottom
Hi, what is this part called. Our washer is leaking from underneath, I replaced the tub gasket but this part is so corroded the gasket can’t seal. What is the name of the part so I can order a replacement. thanks.
Washer support with spin tube ( Whirlpool 280184 Washer Tub Support With Spin Tube | Genuine OEM Part )
Thank you for the fast reply!!! OK I will order on ebay as the part isn’t available on your site. What gaskets etc. should I replace at the same time? Would like to be thorough with this job and replace all associated parts with OEM, to avoid having to tear the washer apart again. :slight_smile: Thank you!
Do you know if this will fit Whirlpool W10863713 Washer Dryer Combo Washer Support Mounting Bracket | Genuine OEM Part
thanks
This if it’s bad corroded It’s the one closest to the back panel ( Whirlpool WP64067 Washer Spring Mounting Bracket | Genuine OEM Part )
These 3 for sure ( Whirlpool WP63907 Washer Suspension Spring | Genuine OEM Part )
These 2 if they are corroded ( Whirlpool WP64065 Washer Suspension Spring Bracket | Genuine OEM Part )
Counterbalance spring kit. Goes between the rear spring holder and frame to counterbalance for the weight of the motor, replace if yours is worn, stretched or corroded ( Whirlpool 285901 Washer Counterbalance Spring Kit | Genuine OEM Part )
Tub seal ( https://www.appliancepartspros.com/whirlpool-seal-wp8577376-ap6013521.html )
Snubber pads located on top of base where the triangular plate sits replace if worn broken or missing there are 3 of them ( Whirlpool 285744 Washer Tub Suspension Pad Kit | Genuine OEM Part )
Usually if you’re going that deep into a washer it’s a good idea to replace the clutch ( Whirlpool 285785 Washer Clutch Assembly | Genuine OEM Part )
Check condition of motor coupling ( Whirlpool 285753A Washer Motor Coupling | Genuine OEM Part )
Looking at that amount of corrosion what condition was your derive block and nut in? ( Whirlpool 285753A Washer Motor Coupling | Genuine OEM Part ) ( Whirlpool WP389140 Washer Drive Block | Genuine OEM Part )
Sorry list is so long but you had a lot of corrosion and I wanted to cover all the major components. Of course you may not need all of them but it at least gives you a list of things to check
This is perfect! thanks! I did the clutch a few months ago and the springs were fine as of last weekend when I tore it part but I’ll get the other stuff. Thank you so much!
Let us know if we can be of further assisstance
Hi, I bought a used tub support on ebay and my leak is fixed. :slight_smile: However, I had trouble tightening the three screws that hold each of the three suspension spring brackets, do you know if I need a special socket? They’re slightly too small for a 1/4" socket. Here’s a link to the screws Whirlpool W10846509 Washer Screw | Genuine OEM Part . thank you!
either a 1/4 or 6/16 nut driver sockets don’t usually work
5/16 sorry miss typed
Thanks again for the help. I have another question. I think my machine is missing two of these. Whirlpool 285901 Washer Counterbalance Spring Kit | Genuine OEM Part I have one at the back and the only other springs I can see run horizontally, attaching the tub to the brackets. Machine runs fine. can you confirm this mode has three horizontal springs and three vertical springs - not one vertical spring at the back only? Thanks.
no there is only one counterbalance spring at the back to offset the weight of the motor
Help! It worked perfectly for three days, now it sounds awful like there’s gravel inside. And it’s leaking again :cry:
Can u identify where the noise and leak are coming from?
I think the transmission is bad, significant play in the output shaft. Decided to junk the washer and return the ebay washer support, which was quite expensive, before the return window closes in two weeks. Thanks again for your help! I would have 100% have put a new transmission in it but such a repair wouldn’t have made financial sense given that the tub was cracked at the top and also needs to be replaced. :frowning:
