Mysterious leak -Top Freezer w/Ice maker
All works fine. I checked the water connection from the water source. I checked the connection at the fridge. The pan is bone dry. Yet, a puddle will appear under the fridge near the back right corner, if you’re facing the fridge. Its only 6 mos old.
There is no drain hose (that can be seen) I tipped the fridge back and removed the drain pan, the drain hole exists, but from a flat plate that has no obvious way to reach a drain hose (if it exists) on the bottom of the fridge. I suspect there is a clog somewhere, but I’m flummoxed as to how to get to it. Advice is welcome! Thanks
Its only 6 mos old.
It should be under warranty. Don’t mess much yourself with it and void your warranty. Call for local warranty service.
Many are now hidden inside the walls.
I want 5 minutes, 1 baseball bat in a dark ally with the designer that thought this was a good idea :wink:
jeff sr.
…let me borrow that baseball bat.
I was one hour on chat hold hell, before I could set up an appt for someone to look at it via warranty coverage…and that, is still a week away. It turns out, a warranty is license to annoy the buyer. I’ve not broken any seals or messed with anything that would void the warranty. I’d be happy to live in a world with no warranties and items that work correctly to begin with.
** I’d be happy to live in a world with no warranties and items that work correctly to begin with.**
Agreed!
jeff sr.
