[SIZE=1]My dishwasher stopped working entirely (no power to control panel etc.) so after investigating I replaced the thermal fuse #22-665-675813 and that worked for a while. Then it died again. I was told by a tech that this could happen and I remember him saying that I might need to change the panel. Can you confirm or correct and be more specific? Thanks! Lou [/SIZE]
Replacement parts for WHIRLPOOL DU920PFGT4 | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208051291.pdf
Did you replace the harness when the fuse was replaced. This is very important. see Item 4 in Section 1, click on the picture to expand it.
That the control board needs replacing is a possibility but there other things that can blow a fuse.
Thanks for your post! I did replace the harness with the one provided with the fuse. Any thoughts? Lou
All you can do is check the components with a meter to make sure they are OK.
Also check that all connections/wires are OK and none are corroded or loose.
If they all measure OK then it is probably the control board but it is still a bit of a crap shoot.
Hopefully someone else will jump in with suggestions.
