My washer will not agitate or spin
When I started the washer it filled with water but did not agitate the clothes. It continued the washing cycle but when it was time to spin it did not spin. My husband checked the belt and it is in good condition. The tub does spin freely if we spin it manually.
The model number you posted does not come up. Verify and repost it please.
The correct model # is: WPRE8150H0WT
Thanks!
Remove the front panel and check the fuse for continuity.
Here are the breakdown diagrams and Replacement parts for General Electric WPRE8150H0WT WASHER | AppliancePartsPros.com
Fuse location and diagram.pdf (95.7 KB)
