I read through the forum and tried several repairs with no success. My washer leaves clothes wet and needs to run a second time on the spin cycle. I replaced the basket drive, the drive coupling and clutch assembly. Also there is no clog or blockage in the drain lines on either the pump or drain hose. Any thoughts on my issue? After spinning a second time they are OK to place in the dryer. Could it be a timer issue? Thank you, JBS!
My issue was the timer - repaired!
