Please help my electric stove the oven the bottom burner will not kick off top burner works fine. ![]()
Parts for Whirlpool RF365PXMQ0 Range - AppliancePartsPros.com
I am not sure what you mean by âkick offâ.
If you mean that it will not shut off and it is red along itâs entire length then odds are that the control board/timer is bad.
Yes Thank you I was meaning shut off the bottom element will not shut off it stayâs red hot. The top element will shut on and off like it is suppose. Thank you for your reply.
Sounds like either the contacts of the bake relay on the control board are welded together or the electronics that control the relay are shot and always energize the relay.
RF365.pdf (149.3 KB)
