My right refrigerator door does not close fully, unless pushed
Brand: LG
Model Number:LFXC24726S /02
Main Symptom: Right Door Not Closing Easily
What happens & when: When closing the door, I have to push it closed. The left door closes properly. The right door has to be pushed closed in order to close all the way. Is there a specific part i need to replace.
When closing the door, does it need to be forced as if it is sticking open, or does it close easily? If it needs to be forcefully closed, the first step would be ensuring there are no items sticking out that might hit the door shelves. This can cause the door to not close properly. If there are no items that might be preventing the door from closing properly, or if the door swings freely on the hinge, the lower door hinge of the right door could be a cause of failure.
https://www.appliancepartspros.com/lg-hinge-assembly-center-aeh36821910-ap5675851.html
