Brand: Kitchenaide Model Number: KODE300ESS02 Main Symptom: Control panel gives error codes and the oven will shut off What happens & when: When operating my top oven and open the door, steam would be released and sometimes cause the control panel to show error codes and shut the oven off. At that point, the control panel does not take any further inputs and I need to shut the breaker off and on to reset the oven and restart the oven. I purchased, as I was led to believe, a new control panel (order number 17150189) and installed the part however the instance happened again. Please Help.
Error Code (if any): ERR:F2E1 and ERR:F1E0
Parts or tests already tried: W11087457
I’m sorry you’re still having the problem after replacing the control panel. Since the new user interface did not resolve the issue, I don’t think the touch panel itself is the root cause.
The fact that it only happens when you open the upper oven door and a burst of steam reaches the control area is a very important clue. Here are the most likely causes, in order:
Moisture entering the control compartment (Most Likely)
Excessive steam escaping around the top of the oven door can condense inside the control housing and temporarily interfere with the electronics.
Inspect the upper oven door gasket for any gaps, tears, or areas where it isn’t sealing tightly against the cavity.
Also check that the door closes evenly and isn’t slightly warped or out of alignment.
Loose or contaminated wiring connection
Since the control panel was recently replaced, remove power to the oven and inspect every ribbon cable and connector between the user interface and the appliance manager (main control board).
Make sure each connector is fully seated and that there is no corrosion, moisture, or bent pins. Even a small amount of condensation on a connector can cause communication errors.
Failing Appliance Manager/Main Control Board
If the user interface has already been replaced and the wiring checks good, the appliance manager (main control board) becomes the next most likely suspect. It processes the keypad inputs and communicates with the display. A failing board can lock up when communication is interrupted, requiring a breaker reset just as you’re experiencing.
Cooling fan not operating properly
The cooling fan should begin running during baking to keep the electronics compartment cool.
Verify that you can hear the cooling fan running while the oven is heating and that it continues for a short time after the oven is turned off.
If the fan is weak or not running, excess heat and steam can accumulate around the controls.
A couple of questions that will help narrow it down:
What error code(s) are displayed? Even if they only flash briefly before the panel locks up, the exact code is very helpful.
Does this happen only with the upper oven, or will the lower oven do the same thing?
If you open the upper oven door only a few inches to let the steam vent slowly instead of opening it fully, does the problem still occur?
Those answers will help determine whether we’re dealing with a communication issue, a temperature/moisture problem, or a failing appliance manager board.
I included the error codes but will include them again. ERR:F2E1 and ERR:F1E0. This happens when the door is opened up so am not sure how the door gasket would be an issue. I don’t believe it ever happened with only using the lower oven. It has happened when we’ve used the top alone or top and bottom. I assume the appliance manager is behind the control panel?
Yes the control board ( Whirlpool W11179310 Electric Wall Oven Wall Oven Control Board | Genuine OEM Part ) is behind the control panel but I’m still trying to understand why you keep having the issue. I mean I know the root cause is the steam condensing on the electrical components but the internal fan should keep the steam from accumulating to that point. I would reach out to KitchenAide about the issue. I’m going to attach a job aid from the manufacturer to see if it provides any resolution
I am going to check on the fan and see if it is operational. For some reason, I haven’t noticed if it was on one way or the other. I assume it should be on the whole time the oven is on.
I tried looking at the fan during the oven operation. I noticed it come on and if I open the oven door to look at food and re-close the door, the oven fan does not restart. I also noticed it does not come on during broil operations
On the KitchenAid KODE300ESS02, F1E0 indicates an EEPROM (memory) communication error. The electronic control has detected an internal communication failure. Depending on the control platform used in the oven, the failure may be in the User Interface (UI) or the main appliance control (ACU).
Start with these checks
Turn the breaker OFF for 5 minutes.
Restore power and wait about 2 minutes.
If the error returns immediately, it is almost always an electronic control failure rather than a wiring issue.
On the KODE300ESS02
Since this model commonly develops control issues after steam escapes from the upper oven, I’d also inspect the ribbon cable and connectors between the UI and the main control for signs of moisture or corrosion. If the connectors are clean and fully seated, the fault is typically caused by a failed electronic board.
Most likely causes
Failed User Interface (display/touch panel).
Failed Main Control (ACU).
Less commonly, a loose or damaged harness between the two boards.
One question
Does the F1E0 appear:
Immediately when power is restored, before you start either oven?
Only when using the upper oven, especially after opening the door and steam escapes?
Only when using the lower oven?
That answer will help determine whether the UI or the main control is the more likely culprit.
There is no further suggested repair per the manufacturer. This is a known design issue for these model of ovens. The only thing they recommend is tightly covering any high moisture foods you cook in the top oven and when you open the door always open it fully and make sure it is fully closed don’t just crack the door open as that directs more of the steam at the control board
