Brand: Samsung
Model Number: FE710DRS
Main Symptom: temperature is not stable
What happens & when: Cooking is unpredictable. Sometimes it takes forever to cook things. Bread will not rise/cook properly in this oven, never browns on the top, doughy center but dried out.
Error Code (if any): none
Parts or tests already tried: Tested the temperature sensor, correct Ohms. Recalibrated temperature but it ranges up to 10 degrees off compared to 3 different oven thermometers. Temp is unstable using Bake and Convection Bake. Both convection fans are working. Oven is 14 years old.
