hello,
i have a maytag microwave oven model # mmv5000bab. i was heating something and heard a popping sound. the microwave has power to it, since the display pad and turnable work but it will not heat anything. i was told there was a fuse in it that could be replaced.
is there a fuse and what does it control, just the fan, the whole oven? i would like to order the fuse but i am not sure where it is located and how to replace it? do you have instructions on how to replace the fuse, if that is the problem? do you have a simple repair manual or sheet that would show how to replace the fuse?
how do i troubleshoot to make sure that it is indeed a fuse problem and not the whole microwave shot?
thanks in advance for any help
david welch
valparaiso, in
