My ice maker auger will not stop spinning when the door is closed
Brand: Frigidaire Gallery
Model Number: FGHS2355PF2
Main Symptom: Ice auger will not stop spinning
What happens & when: It intermittently starts and stops. The ice flap also remains closed and a massive build up of ice occurs.
Error Code (if any): None
Parts or tests already tried: I tried replacing the jamb switch. Unplugged the fridge for 15 min and replugged in, did not work. I check for any ice build up in the ice maker, all clear. I check the operation of the start stop ice flap, also ok there
With the dispenser motor running continuously, this will most likely be an issue with the dispenser control board.
https://www.appliancepartspros.com/frigidaire-user-interface-5304527932-ap7017396.html
Thank you! And lastly where would I find and access this part to replace?
