Brand:frigidaire
**Model Number:**fghs2355pf4
Main Symptom:no ice
What happens & when:no ice
Brand:frigidaire
Main Symptom:no ice
The first thing to check would be to make sure that there is 120 vac to the icemaker. If there is then check to see if water is getting into the icemaker. If there is water in the icemaker but not ejecting it then this wiill be a faulty icemaker. If there is no water getting into the icemaker then check for a frozen fill tube. Cycle the icemaker and see if there is 120 vac to the water valve and if there is but no water then replace the valve.
