My dryer squeals and doesn't dry properly
Dryer doesn’t spin properly and squeals. I think it might be a rear bearing.
Very likely this is the cause of the problem. You also may want to check the upper and lower front seals and the belt.
Here are the breakdown diagrams and Replacement parts for FRIGIDAIRE AGQ6000ES2 Frigidaire/dryer | AppliancePartsPros.com
Dryer disassemble procedure.pdf (34.5 KB)
