My dryer recently stopped working out of no where. It would begin to heat and then cool down, and of course not dry. I did some research and found out I could replace the thermal fuse so it will heat up but it didn’t work it heats up a little bit more but just like before it begins to heat just fine and then dwindle. Please help I don’t know what to do and getting a new dryer is a little expensive right now.![]()
I suggest you might look into local laundry equipment services that can assess it and suggest the correct route to get it fixed!
