My dishwasher has no lights or noises
Brand: Bosch
Model Number: SHE46C06UC/46
Main Symptom: No power. No lights. No error codes. No noises.
Error Code (if any): none
Parts or tests already tried: I replaced the power on/off switch. same issue. I did some voltage checks and have 85 volts across 7.1(GYBK) and 7.2(RD).
If there is not 120 vac to the switch then this will be a faulty control board that would need to be replaced.
I have 120 vac to the on/off switch, and 120 vac from (N) white to the GYBK (7.1) wire on the plug into the control panel. Only have 6.5 vac on the white(N) to the red wire(7.2) on the same plug out of control panel.
It sounds like an issue with the control board and it would need to be replaced.
