MVWB865GW0 Maytag Commercial Technology Wont Fill
Brand: Maytag
Model Number: MVWB865GW0
Main Symptom: Won’t fill
What happens & when: MVWB865GW0 Maytag Commercial Technology top load washer having problems.
It would not fill. We replaced the inlet valve, still nothing, replaced water pump and nothing. Then discovered how to put into diagnostic mode and it said clutch so we replaced the clutch and now a new error code comes up of F7E5.
All hoses and drains are clear. Wiring all looks to be intact. Control panel seems to be functioning fine as far as lighting up and responding to cycle changes and button selections. But washer won’t fill and goes from sensing to wash, agitator moves a little and after a few minutes it ends the cycle.
Error Code (if any): F7 E5
Parts or tests already tried: Inlet Valve, Water Pump, Clutch all replaced
The error F7E5 points out a shifter failure. If there wasn’t an issue, loose wire, or misaligned part during the clutch replacement, the main control would be the issue. W11401710 Electronic Control Board | Genuine Whirlpool OEM In Stock
Appreciate the help. Have ordered the part. Will update after install.
