Mtr replacement
[FONT=Times New Roman][SIZE=3][COLOR=#000000]My wife called a repairman he said that the dishwasher needed a mtr, the mtr works, is there a way I can test the motor it doesn’t seem to be failing. [/COLOR][/SIZE][/FONT]
If you have a multimeter,
Disconnect the motor harness, and do the following tests on the motor :
White to Yellow 6.5 ohms (wash winding).
White to Gray 6.5 ohms (drain winding).
White to blue/wht 1.8 ohms (start winding).
Give yourself 10% high or low and your motor will check to factory specifications.
What is your actual complaint ?
:cool: :cool:
