Washer does agitate and most of the water drains but not completely. Clothes are still dripping wet. Checked the belt and seems ok. What’s next? ![]()
Difficult to say on a machine this old. Check the pump and the drain lines inside the machine for any obstructions if you have not already done so.
[QUOTE=sidfink43;893745]Difficult to say on a machine this old. Check the pump and the drain lines inside the machine for any obstructions if you have not already done so.[/QUOTE]
Thank you…I’ll check the lines
