Mouse chewed sensor wire (LG)
Hello. A mouse chewed the connector from the sensor on the front of the sump, visible behind the kickplate. Sensor had 3 wires going to it; black grey, white. I need to know the order of the 3 wires to make a new connector.
For example… black, white gray (from left to rite)
Thanks!
I could not find info on your specific unit hopefully the following is a close match.
http://136.166.4.200/contents/Dishwasher/LDS5811/LDS5811_Service_Manual.pdf
I am assuming you are referring to the soil sensor.
Pin 1 - White
Pin 2 - Black
Pin 3 - Grey
Often pin numbers are marked on the plug body or pin 1 will be marked.
Sorry I could not give you a definitive answer.
Thanks very much. I’ll give that a shot and see if it will work properly.
I could measure to determine ground pin… it shouldn’t destroy the sensor if i reverse VCC and Vout.
Will post with the results!
