The ram hammers at the end of the stroke. I opened it up, tested the switches. They are all electrically good. While watching the motor, I see that the switch is not pressed at the bottom of the ram stroke. When I press the plate which touches the motor switch, then the ram comes up again like it should. How do I fix or adjust this?
thanks!
