Motor shaft replacement
The square plastic vertical shaft snapped about 1/2" above the seal. Is this repairable, or do I need to replace the motor?
You will have to buy a new motor.
Parts for Frigidaire FDR252RBB2 Dishwasher - AppliancePartsPros.com
If you click on a part’s description or picture a new page will open often with more views and info about that part.
