motor and compressor make humming noise
My fridge makes a humming noise very frequently when it comes on. I have had this fixed in the past, and the repairman replacedthe motor, but it is now doing it again in less than 2 years after the repair. Is there a different solution besides replacig the motor.:mad:
Which motor are you talking about and where is the noise coming from? If you have a noisy evaporator motor, the fix is usually replacement of the motherboard in the back AP4436216
