Monogram ZGP486NDR5SS
Brand:
Model Number: ZGP486NDR5SS
Main Symptom: When dial turned to broil mode both the displays turn blank
Error Code (if any): No error code
On the GE Monogram ZGP486NDR5SS, if both displays immediately go blank only when the oven selector is turned to BROIL, I would not start with the broil igniter or burner. This model uses electronic display/control components, including a control display module (WB27K10304) and encoder assembly (WB24K10081).
The fact that both displays lose power points more toward the selector/encoder circuit, control power supply, wiring, or a component pulling the low-voltage supply down when Broil is requested.
Quick test first
Turn the oven selector through Bake → Convection Bake → Roast → Broil.
Watch the displays carefully.
If every other cooking mode works normally and the instant the knob reaches Broil both displays go completely black, then turn the knob back out of Broil.
If the displays immediately come back on, that’s an important clue. It means we’re probably not dealing with a general incoming-power problem. Something associated with the Broil command is pulling the control circuit down or causing the electronics to reset.
First suspect — selector/encoder
This range uses encoder assembly WB24K10081 in the control system.
Because the failure occurs specifically when the knob reaches one position, I’d inspect the Broil selector/encoder and its wiring first.
With power disconnected, access the control panel and inspect the encoder connections for:
  • Loose or partially backed-out connectors
  • Burned terminals
  • Pinched wiring
  • Corrosion or contamination
  • A connector installed incorrectly
  • Damage around the selector/encoder
If moving the selector slightly into or out of the Broil position makes the displays blink, reset, or come back on, that makes the encoder/selector circuit especially suspicious.
Then isolate the Broil load
The ZGP486NDR5SS is an all-gas range, and the parts breakdown shows separate broil burners and glow-bar igniters.
If the display stays powered until the control actually attempts to energize Broil, disconnect power and temporarily disconnect the broil igniter circuit.
Restore power and select Broil again.
If the displays now remain on: investigate the broil igniter wiring and load for a short or abnormal current condition.
If both displays still immediately go blank: I’d move back toward the encoder/control/display power circuit rather than replacing the broil igniter.
What I would check before ordering anything
Since both displays are affected simultaneously, I’d diagnose this in this order:
Broil selector/encoder → encoder wiring/connectors → control power supply → display/control module → Broil output circuit/igniter.
I would not replace the broil igniter just because Broil isn’t working. A normal failed glow-bar igniter generally gives you a no-heat/no-ignition condition; it doesn’t normally explain why both electronic displays completely lose power.
If you have a multimeter, the next really useful test is checking whether the control/display supply voltage actually disappears when Broil is selected. That will tell us whether the displays are being commanded/reset or whether their power supply is collapsing.
