The broiler in the 12" oven side will not go on. The fan will start but no indicator lights and no heat. The other functions such as Bake and Proof work normal and the indicators lights also work. Any suggestions as to parts and repair needs?
I would suspect a bad broil element. You can turn the breaker off, remove the element and check resistance of the element.
