Symptoms -
Blown fuse after heating something and closing the door.
Replaced fuse - Control Panel functions, light turns on inside when door is open.
When entering cook time or quickstart - when start is pressed you hear a click sound from the relay - timer counts down - but no power to turntable, fan, inside light.
From everything I have read, does this sound like the monitor switch is bad?
Thank you!
