Monarch Garbage Disposal
[FONT=Arial][SIZE=4]I have removed the Monarch garbage disposal but cannot remove the flange that is in the sink it is the type with threads that threads into another flange the 2 parts are rusted together and loose from the sink which means that I have to hold 1 part and try to turn the other part s there a special tool to separate these 2 parts.[/SIZE][/FONT]
there is no special wrench for this.
the large nut on the bottom of the sink that holds the flange in, is a flunky metal.
you will have to chisel it to break apart.
[quote=scott5495;821602]there is no special wrench for this.
you will have to chisel it to break apart.[/quote]
[FONT=Arial][SIZE=4]I was able to break it apart from the top using needle nose pliers[/SIZE][/FONT]
[FONT=Arial][SIZE=4]it was made out of plastic pretty easy to break.[/SIZE][/FONT]
This is exceptionally pleasant and better than average post..spanish programs - how to learn spanish
..You shook posting it…Thanks a considerable measure for posting it…!!!
