Hi all,
I have a Whirlpool Duet washing machine. When you open the front door, there is a large grey rubber seal which has gotten disgusting :eek: with mildew and will no longer come clean. I want to replace this. Would you please tell me what part(s) are needed to remove and replace this? Also, do you have some basic instruction on going about this process? Thank you very much!
Replacement parts for WHIRLPOOL GHW9100LW1 | AppliancePartsPros.com
And this should help with your repair.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/eab852a13fbc842085256aa200643dd6/$FILE/Duet%20Job%20Aid.pdf
AP6011740
Click on the picture for more info.
Also check the spring clamp (Item 14 in Section 2), if it is rusted up I would also order one of them.
Thank you for your help…greatly appreciated! ![]()
