:rolleyes: My mixer will only work in high speed. What part do I need to replace?
Tblack,
There are 2 possibilities,based on your description,
A broken Control Plate Spring
and or a bad Motor Phase Control Assembly
You’ll have to remove the end cover plate from the back of the mixer “head” and the side trim plate screws to access the phase control and the spring, after you raise the upper housing from the lower housing by removing the screws holding the assembly together.
Good Luck,
How do you repair these parts?
I meant replace this parts?
Any instructions?
[quote=tblackw;426487]I meant replace this parts?
Any instructions?[/quote]
The manual is not a PDF file, I can’t attach it to a response.
If you can send me a fax number, I’ll be happy to send you the appropriate information, to assist you.
[quote=Joe / APP Team;426581]The manual is not a PDF file, I can’t attach it to a response.
:)[/quote]
Fax:[phone removed]
Need instructions on how to replacing the phase control board on my Kitchaid Mixer, Model K45SSWH.
[quote=tblackw;435544]Fax:[phone removed]
Need instructions on how to replacing the phase control board on my Kitchaid Mixer, Model K45SSWH.[/quote]
Tblack,
Just faxxed the pages from the manual for you.You’ll have a few extra pages.
Ron,
Did you not recieve the service manual we faxxed ?
