Our dishwasher is filthy so I went online to see how to clean it. I mean really clean it. I found a video where this person has the exact same filters as us so I watched it. It’s very easy to remove the parts and put them back. The only thing is, there happened to be a washer that came out of place when we went to put everything back. I had an idea as to where it went but when I ran a test wash, there was a leak. I have no idea where this washer goes. We have a GE Profile GSD6000. The manual says nothing about any washer.
Your model number is missing several digits at the end.
Please choose the correct one from the Matching Model Numbers section and also let us know so that we have a common reference on the unit.
Sorry but there are loads of washers in a dishwasher so I cannot help.
Perhaps adding the following info would help.
Describe the washer or take a picture of it with a ruler beside it and add that info to your post.
What exactly did you take apart or perhaps the link to the video you used?
Where is the leak?
Could be that the washer is not the problem but taking the unit apart created the leak.
