Miss T
My Dishwasher Will No Longer Light Up. But It Washes Or Normal Cycle Only. What Do I Need To Replace?
Replacement parts for MAYTAG MDB9600AWS DISHWASHER- UNDERCOUNTER | AppliancePartsPros.com
Here is a service manual
http://appliancedigest.com/index.php?/files/file/474-16021814-maytag-jetclean-ii-dishwashers-service-manual/
You may have to join the site to down load the manual but it is free and a good site to belong to.
Check behind the kick plate to see if the tech sheet is there. It should give the pin-outs for the keypad/control panel. Then you could check it with a meter to see if the switches are OK.
Your problem can either be the control panel (Keypad) or the control board.
Without a keypad wiring diagram it is a crap shoot as to which one is shot.
Check all the keys to see if any other keys work. The reason that you do this is most keyboards use a common line for a number of keys so if that line breaks you loose about 3 keys. If this is the case I would replace the keypad first. Still not 100% that it is the keypad but your odds are better.
I would try the following before ordering anything.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
