Mircowave not heating
Brand:
Model Number: GE JVM3160DF4CC
Main Symptom: Loud humming but no heat
What happens & when: It turns on, has lights turntable works, but loud humming while on, humming stops when it times out. Haven’t tried parts yet. Might be cheaper just to buy another one?
That hum usually indicates a bad magnetron WB26X23320. If the magnetron failed due to a damaged wave guide or damaged the wave guide when it failed then the appliance is non-repairable since that wave guide isn’t serviceable.
The magnetron also may have damaged or been damaged by other high voltage components.
https://www.appliancepartspros.com/ge-magnetron-wb26x23320-ap6040604.html
