Brand:GE Model Number:JB735SP1SS Main Symptom: Middle of element not working, the outer layer works What happens & when: Middle of element not working, last week
Error Code (if any):no error code
Parts or tests already tried: switch does turn on the outer layer of the element
Hi ztsang250, is this the original burner, or has it been replaced before? If it’s the original burner, there’s most likely a burnt or damaged coil somewhere in the burner, which would explain why it won’t turn on.
Hi ztsang250, do you hear any flickering, crackling, or static-type noise when turning the knob? To check, slowly turn the knob in both directions and listen closely.
If that checks out, unplug the range and remove the back panel. Look for any burnt spots, damaged wiring, or a burnt smell around the switch and connections.
If everything looks good there, then the burner itself is most likely the culprit.
You will need to call Customer Service and go through the warranty replacement process with them. They should be able to help you with the next steps for getting the unit or part replaced under warranty.
