Microwave whirlpool GOLD
Please help appliane pros
The light bulb burned. Wondering if its a regular halogen I can buy at the hardware.
Also, any one can give me step by step instructions
I heard the whole unit needs to be taken out with the white borders removed first. I cannot locate the plug and I suppose it is behind the unit and I will see it when I remove it.
Hi Johny,
You were right. The microwave has to be removed from the oven body. The instructions are attached to the reply.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GSC308PJQ4 OVEN WITH MICROWAVE | AppliancePartsPros.com
Removing the microwave.pdf (546.0 KB)
Removing the convection temperature sensor - the halogen lamp - the cavity thermal fuse.pdf (461.5 KB)
