The turntable starts to turn about 1/2 a revolution and stops. I am thinking that it is the turntable motor that needs replaced on this unit that is mounted in our kitchen. The glass tray turns freely with no resistance. Could it be some other problem?
If I purchase a replacement motor, is it hard to install? Can it be replaced from under the unit without removing it from the wall bracket?
Do you have any replacement instructions to follow?
I know this is a lot of questions, but any help would be appreciated.
We’re having the same problem with our Jenn-Air JMC7000ADB microwave – the turn table does not turn. The spindle turns when the glass tray is off but will not turn when it’s on there. I’m pretty sure the motor needs to be replaced. Is this something that can be performed by a weekend DIYer or does it need to be done by a professional? Here is the part:
I am also having this problem with a GE spacemaker xl1800. I am also having trouble with the light, it doesn’t work on the first (low) setting but does on the high setting. Any help would be great.
Sorry to not be more clear, the light problem started about 1 year ago and the turntable happened after we put a large heavy dish in and forgot to turn the turntable off. It still seems to spin till you put the glass plate on, then it won’t turn. I can live without the nightlight function but not the turntable.
Thamks again.
Scott
The coupler seems to be ok, should it just pop off, I don’t want to pry it off and break it? My wife said she has heard a grinding noise which I have not heard.
Thanks for taking the time to answer my questions.
Scott
I pulled it out and it was broken so either I broke it pulling it out or it was already broken. I will order the piece and see if that does it.
Thanks,
Scott
I’m having the same trouble as well. The turntable will not rotate. I have a Frigidaire model# GLMV168KQ3 manufactured in January of 2002. Please help me troubleshoot. By the way the button to push to turn the turntable on and off does beep like it is trying to work and the display shows like it is being turned on and off, just not rotating!
I am having the same problem with the Frigidaire Gallery CFMT148GPB2. Turns half a turn sometimes with the glass plate, turns very slowly without it.
Would someone be so kind to provide me with a diagram and the required part numbers for this model?
Thank you very much.
Hi Gene, thanks for your reply.
I’m actually in Canada. When I google part of the model number I find CFMT 148GPB1 which I assume must be the same unit. Date on the tag says Jan. 2000, don’t know if that helps. It’s an over the range microwave from the Frigidaire Professional line.
Hope you can help, thanks.
Hi Gene,
I discovered that the model for my microwave is actually the FMT148GPB2, all I had to do was drop the C.
I took out the turntable motor which seems to be defective, the model is ST-16FE(EX73SAAA3). I could not find this part on your site, do you sell it under a differnt part#?
Thanks a lot for your help.
