my turntable will turn if I turn it prior to starting the micro but only for a short time then stop. Why is my turntable not working
Hi.
You need to check two things:
First check if the slot in the middle of the support is intact
[AP4360111](http://www.appliancepartspros.com/frigidaire-support-assy-5304467717-ap4360111.html)
Then using the multimeter check if there is 120VAC to the turn table motor when the microwave is ON.
If the proper voltage is present - replace the motor
Here are the breakdown diagrams and Oven / Cabinet parts for Frigidaire FMV156DSB - AppliancePartsPros.com
Post the results.
Simon.
