The microwave turns itself on and sparks when it does. When I turn it on it programs itself. What do you think is wrong and do you have the parts I need?
Does it do it with the door open?
Did you notice where does it spark?
What is the serial number of the microwave?
Here are the breakdown diagrams and Replacement parts for AMANA M1020E Mwave - Cntrtp / Stand Alone | AppliancePartsPros.com
[quote=Gene;223414]Does it do it with the door open?
Gene.[/quote]
It did not do it when door is open. Yes it did spark
serial number P1319603M
Did you see where the sparks are coming from?
I don’t know. The Plate on the inside has a hole in it. The plate is on the right side as you look in. Is it safe to turn on?
