The microwave stopped working…no power…no on light…
the oven works, all lights work except the on (for Microwave)
Is there a reset button… or is that too simple???
help any suggestions at this point.
The MW will be controoled by it’s own fuse. Most likely a 20 amp. Usually a fuse blows for a reason. Sometimes, albeit rare they will just blow. I would locate the fuse and replace it one time. If it blows again then you have a deeper problem.
