Microwave Repair
Hello, I have a Magic Chef Microwave Oven model MCC1010 and the problem is when I try to Microwave something it work for about 30 sec and then it shut down. When I run it on grill it works fine. Can someone please help me with this problem.
Thanks,
Lance
Lance,
Open the control panel and check the cooling fan and its blade. The model number you posted does not come up.
Thanks Gene,
The Model number is MCC1010STG at web page.
MC Appliance Online Part Order page 1
One thing I did notice is alot of humidity when it runs for about 30 sec and shuts off.
mcappliance.com in the part oder section MCC1010STG
This site is just to order parts. We need the diagrams. I suspect this microwave is actually made by E-Wave and one of most common problems for these microwaves is a fan blade slid out of the motor shaft causing the magnetron to overheat.
