[LEFT][COLOR=#000000][COLOR=red]How do you remove the old snap in plastic rack holder from Jenn Air microwave Model # JMV8196AAs. just received new one (s) form APPros.[/COLOR]
[/COLOR][/LEFT]
You will have to remove the cabinet from the microwave. You will see the clips on the outside of the cavity. You can release these clips there, or you can use side cutters to cut them out. Be sure the power is disconnected and be careful around the HV componets inside the unit. The new ones will snap in from the inside of the microwave. Hope this helps.
