When the door to the microwave is opened the turntable rotates.
The microwave heats some times. The oven works fine. Any help would be greatly appreciated. Thank you in advance.
You have to remove the microwave from the oven cabinet, remove the outer case and check the door switches.
Here are the breakdown diagrams and Replacement parts for GE JKP85BA2BB | AppliancePartsPros.com
Thanks for the quick reply.
I am going on vacation so I won’t work on it until about the 27th. Are the switchs normally open or closed.
thanks
alan
[quote=Gene;117697]You have to remove the microwave from the oven cabinet, remove the outer case and check the door switches.
Gene.[/quote]
